- Mar 8, 2008
I consider 4116 as being very similar in performance to SAK steel. High corrosion resistance, good toughness, moderate edge retention, high ease of sharpenability.
I thought the test was pretty decent. What makes the Krupps a bit above average is the vanadium in it. That is why I think it cuts so well. I don't own a Krupps steel knife but I am pretty well satisfied with the results of this test if I ever decide to get a knife with it. As for thicker cardboard and what not, give me a break. It did well on a pizza box by along shot. What I'm going to go out and get some double wall thickness 150lb breaking strength to test a knife? Sometimes folks on here don't make sense when it comes to testing a knife. It cut up a bunch of cardboard very well, that's the bottom line. The rest of you folks can't stand to see a CS product do well no matter what me thinks even one of there cheap knives. keepem sharp
It's really nothing but a cheap and or low cost steel and nothing more than that.
That evaluation make me think....
This type of stainless steel becomes extremely sharp & takes a coarse edge well too....Personally I love 2 fact, 1# works well #2 ain't as expensive as some crap out there.
Steel130 Nice test Thanks.
Take the cost factor out of it and just look at straight performance compared to other steels and we have what is called reality without BS, opinions etc.
It's not even in the same class as steels like N690 and VG-10...... Not exactly expensive steels here either by the way.
It is in the same class as 420HC.....
Steels don't perform just because we want them to, they either perform or they don't due to the alloy content, HT and tempering process.
That's the difference between BS and facts.
"X50CrMoV15 also Known as Krupp 4116"
It just shows how many people are speaking from perception and not experience. Now I am not saying that you can not find such blades with low performance (12C27, etc.) as those steels are used on some cheap knives, but you can not dismiss the steel out of hand as a poor knife steel (and all the similar steels, like 440A, Krupp, AUS-6A, etc.) and then say 52100 is a great steel. Verhoeven measured the edge holding of 12C27 vs 52100 and found as expected that 12C27 was superior.
This is one of the largest sources of bias in the online knife community. For some reason stainless steels have to have a high carbide volume to be considered high end but alloy and tool steels do not. It is just maker promotion as you can't forge high carbide steels well so all the ABS guys will use very low alloy/carbide steels for practical reasons. Snobbism and BS have the place too, but credential its a different story "S30V its expensive & crap if talk to me"
Good post. Good points. I was wondering and this is somewhat off topic. Is RC hardness the only type of hardness steel has? Like it seems that cheaper steels are usually more prone to bending and denting. And more expensive steels are more prone to chip or snap. Is that just coming down to alloy contents?
For example....
CPM-S90V may have a great edge retention, but also may crack under my teeth...right?
In a fix of 10" made 4116 Krupp vs 10" made of CPM-S90V.....4116 Krupp will out perfom CPM-S90V on chopping.....especially in cold temperatures.
Wich one the 2 it's a supersteel? wich of the 2 is more expensive?![]()
I gotcha. I will see if I can do some surfing on the web to find some reading material.It's not just the hardness, it's the tempering process also.
That would be a long drawn out discussion......
For the most part I was making full cuts with the knife. Part of it could be the camera angle. It was behind me some. However this was my first go so I have some practice still. Thanks for the reply. And tip.
Thanks man! Im trying my best to do quality videos. On a college student budget haha.Practice makes perfect !
Looking forward to your next video !
1234,,,,,![]()
Believe me they can make choppers out of S90V that will hold up to that type of use, it all depends on how the blade is tempered etc.
There are other options that would be a better fit though, making a chopper out of S90V would be a waste of good steel.
