- Apr 7, 2020
Hi all, looking for a bit of advice. I’m making a small knife with 440B, an ornamental sgian dubh style knife. It’s my first attempt using stainless and I’m only set up for oil quenching. I bought the 440B because they didn’t have 440C and the carbon content of this particular steel is .93%, not far off the .95% of 440C and good enough for my needs. I’ve just finished heat treating it and after tempering for 2hrs at 150C my 65hrc hardness file is skating over it and doesn’t even leave light scratches. I know the hardness of this steel is meant to be 59hrc max so what’s going on?
If my temper has failed in some way, how hard does 440B get before tempering? I would have thought that given 59hrc max at such a low temper temperature it would be softer than 65hrc straight after quenching. I didn’t bother checking at the time because the final hardness wasn’t critical, anywhere mid 50’s would be fine. The problem is if it is too hard it will be brittle.
My heat treat in a gas forge with thermocouples fitted was heat to 800C and hold for a few mins to let the blade heat up then raise the temp to 1025 and hold for 10 mins before quenching in warmed Rye oil 32. Knife was coated in ATP 641 prior to heat treat. After cleaning it up I clamped it between two steel plates then put it in the freezer fo 20mins, (every little helps), then straight into the oven. First cycle was an hour and a half to give it time to warm up. Took it out and quenched/cooled then back into the oven for another hour.
Did it need more time due to the steel plates, both 6mm thick or am I missing something
I use the same steel plates for my carbo knifes to prevent warping with no problems but that’s at higher temperatures.
