440C for liner lock?
I'm making my first linerlock folding knife and I'm using 440C for the liners. Should I heat treat it or use it annealed?
It seems to work fine annealed, but for better wear resistance would you recommend heat treating it?
If so, what kind of temper? Thanks. :thumbup:
If it were just liners like in a slip joint or lock back I'd say the unhardened would work but you are better off to heat treat it in my opinion.
For the liner lock you want to heat treat it for a couple reasons. Spring the lock where you want it and have it heat treated that way. It will be better at keeping that memory once done. Also, drill and thread any holes you want in it before heat treat, and most importantly heat treating the lock will make it wear much better against the blade than annealed. The annealed state will allow the blade to have its way with the lock indenting it and deforming it with shocks from use so yes get at least that side heat treated but honestly I'd do every metal part in it that you use if they are not hard already.
Talk to Peters Heat Treat Service or Texas KnifeMaker Supply about getting it done. You will probably get a better deal with either of them unless someone here chimes in to give you a hand if you can't do it yourself. Most places anymore seem to have minimums so it may be something you want to shop around for or talk to someone about sending your parts in with theirs to cut cost on your end. 440C can be run with other steels so its not going to be a big inconvenience for most I don't think.
STR
Thanks Steve. :thumbup:
I e-mailed Paul Bos and he recommended Rc 46-48 when using 440C for a liner/ framelock.
Peters Heat Treat recommended tempering at 980F for this range when working with 440C.
Just an FYI:
Heating the lock with a blowtorch until it's orange and letting it cool in air, followed by a second heat until it's blue works pretty darn good too. I've tried this on my personal edc and abused it for over a week and there is no wear.
