- Sep 18, 2020
You might be right about the undertempered. Although I put it in the forge at +/-550°c 1000f it only stayed in for about half an hour. To be clear, I had no intention to make a perfect blade as it probably was already overheated. It was just scrap to do a little bit of testing.If the M2 is not etching then it is probably under-tempered. You will need to temper at or above 1000F to get the M2 to etch dark. The problem you have is the two materials are not metallurgically compatible at all. Heat treat, corrosion resistance is all on opposite spectrums.
When I finished grinding the one that worked out properly I'll send it to Austria for proper heat-treating.
I know the two materials have vastly different characteristics, I don't know if that makes them incompatible. There's lots of historical precedents that shows San Mai has its value. But at least in my opinion not when you use two similar steels. Wether that makes 440/M2 the 'mariage parfait' is still up for debate. I'll see when I destroyed the good knife
