Heat treating isn't really something you get "more" or "less" of. More like there are "good" heat treatment processes, which get the maximum amount of performance out of a steel, and "bad" heat treatments, which don't get the steel to perform anywhere near its full potential. And, of course, everything in between. ("Performance" being defined in terms of durability, edge holding, ease of sharpening, e.t.c) A quick google search on knife heat treats, e.t.c, will fill you in on the details.If 440C is said to have greater edge retention, is harder to sharpen and has less toughness than 1080; and if heat treatments are a factor in this result; are we assuming that 440C is subjected to more heat treatments than 1080?. Is it possible for one smith to perform less heat treating on his 440C and another to perform more heat treating on his 1080 such that the 1080 has the greater edge retention of the two?
It's also worth noting that simple carbon steels are easier to work with than stainless ones, especially if the maker forges their blades.Depends on the type of knife. It's purpose. A "survival" or hard use knife benefits from a tougher alloy. A hunting knife benefits from superior edge retention.
Keep the knife you like best, or the 440C if you don't like rust.
I would think that any maker of quality knives would heat treat their own blades. If so, this suggests that a 440C blade has more work (i.e., money) in it than a 1080 blade..?
No, but just saying to keep in mind other features and that you would likely be better served by selecting based on them. If it was the same model in two steels, then select on the steel alone. But if the ergonomics, aesthetics, blade shape, and edge geometry are different, then start there. It doesn't matter what the steel is if the handle hot spots to slow you down. Edge holding is only important for reducing sharpening time relative to cutting time. The effectiveness of the knife design also affects cutting time.Awk! Who likes rust? Surely keeping a carbon steel blade does not doom one to slowing seeing his/her blade oxide away...![]()
440C will hold an edge longer than any 1000 series carbon steel, including 1080.
I would rather use a 1080 blade at 62+ HRC than a 440C one at 59 HRC. It wouldn't resist rust but it would take a great edge and hold it longer than you'd generally expect.
In looking at the McCarty, the width of the blade tapers to a max thickness of 5/32" at the hilt and then tapers back to 3/32 at the end of the handle (the handle is very nice stag). The Buxton is equally attractive with desert ironwood handles and the blade shows a distinctive temper line. The McCarty is definitely the heavier of the two but the blade of the Buxton is presently the sharper of the two. Neither have been sharpened (to my knowledge) since being first sold.
I like the heft and feel of the McCarty but I honestly feel like the blade on the Buxton is better. And after all, isn't the blade is the most important part of a knife?
If I was going deer hunting, I'd dull the blades of both knives and then re-sharpen both of them.
The thickness of the blade is really of no consequence
Ask Roman Landes. He's the fella who made that line famous.
Oh my... surely this can't be like asking two engineers for an opinion and getting 4 answers. Do I need to make this a poll question...??
Edge retention and wear resistance aren't exactly same thing, so don't be confused.
Edge retention has broad meaning, depend on which job you are doing. If you are chopping, then the toughness will play a big role on edge stability but if you cutting some cardboard, then the main factor would be wear resistance. The edge hardness which known as HRC will be the primary attribute regardless of any job, it also known as edge deformation resistance.
Any knife edge is steel and actually measure in HRC
I’m certainly not the most experienced hence my opinion has far less credibility than many of the people here. That said, from my experience (please don’t quote me or rip me for my input, I’m pretty new to this), the 1000 steels, specifically 1084 is more ‘heat treat’ friendly and knife makers tend to maximize its hardness capabilities more consistently. 440c with an adequate heat treat will hold and edge pretty well however, imo, not quite as long as high carbon steel.This question has almost certainly come up here before but my search did not find it... I'm choosing between two knives for use in dealing with deer and elk and am interested in which is more likely to hold an edge for this type work. Both knives are from well-known custom makers and so both would have had their respective steels treated in the best possible ways. The two steels are 1080 and 440C.
I understand these steels are totally different. But is one better at holding an edge? What about the ability to sharpen? Thanks
Great! This the type information I was looking for. Except in this specific case, I already have the two knives and want to gift one to a family member. I was wondering if I should keep the one with 440C or the one with 1080 (for my deer gutting/skinning needs).
