- Dec 30, 2013
Hi bladeforums,
This is my first post here, been lurking for a while. I have a heat treat question. I am working on a pair of very large 18" chef's knives in 440C. Unfortunately both came back from the heat treater warped. I have had blades warp before and was successful in flattening them during temper by clamping them a little past flat in the other direction. Unfortunately since these were heat treated by TKS, tempering and cryo treating had already been done. I poked around for other solutions and found none, so I went ahead and rigged up the jig and threw it in the oven. Several attempts later on both blades at increasing temp and time, I still have warped blades. One is close enough I'm about ready to call it good, the question at this point being, is the heat treat totally ruined? I don't have a hardness tester, I ran a file over the edge and it didn't bite hard, but I was able to remove some material with a few passes. Effectively these have been tempered roughly 5 times now including the original at TKS, and by me, at temps up to about 480, which is as hot as my oven will get. About 2 hours of soak time per pass. Should I forget about using them without heat treating again? If so, how can I get these all the way un-warped? I have a blower I use for heat treating O1 knives with charcoal and a regular kitchen oven, but nothing other than that. Suggestions, comments, etc all appreciated. I have a lot of hours in the grind on these knives, really hoping they're not garbage.
Since I'm new here, here's a little of my work, starting with my first knife years ago
Somewhere along the way
First big kitchen knife
And one from the current batch, my new knife to hunt with.
