Nathan, any idea when you might have some 4V knives for sale and what type of knives they may be?
I have a sheet coming in next week which we'll be using in some upcoming development work. We're experimenting with it and will hopefully have something pretty good by the end of the year. I'll start with the EDC because that's a good form factor for R&D but my end goal with it is a racing chopper.
4V will never have the toughness potential of a lath martensite like 3V, but it has some pretty cool properties for folks interested in edge retention and thin geometry, if we can dial in the edge stability. That large carbide volume is a double edge sword. It improves abrasion resistance and compressive yield strength and may generate more eta carbide (which can augment strength like aggregate in concrete) but it also has lower ductility and impact resistance. If we can get a good balance of properties with it we will probably offer it on various projects where gross toughness isn't a primary driver.
What about something like your D2 skinner, but in 4V Nathan? Any possibility of seeing something like that in the future?
Possibly. But D2 will probably run circles around it in a skinner.
I'm a little worried about D2 taking a chip if I have to split joints breaking an animal down, but it sounds great for clean cuts.
Dozier has been using D2 for a long time, in knives intended for hunting/skinning/game processing. Seems to work well for him, with his HT protocol.
I've seen a lot of the cheap knock-off knives using D2 (supposedly) and it had kinda lowered my opinion on it, plus I think a lot of makers and such favor others (like A2 and O1) over it (at least it seems that way to me). But with Nathan's talking about it and providing a better understanding of perhaps where it would fall in a potential knife line up its got me interested for sure. I know heat treat is critical for these things. I always did like that it was semi-stainless as well
this one is S35VN, hollow ground, but I'd like it stouter via flat grind. This 4V stuff looks like it will take and hold a super fine edge, which is great for bushcrafty, woodworky things, and also for fleshing/skinning type stuff I'd imagine. Corrosion resistance is not a big deal for a knife like this, compared to the attributes mentioned. Might be a great knife for your standard outdoorsy person.
the handle is slim, and the blade is around 4". Bigger than the edc, smaller than the fk.
the recurve you're seeing isn't, the edge is straight, up til the belly. In use, carving sticks and such, I don't know if more belly would be an advantage, but that's a speculation. Lots of leverage and control with this pattern
I love me some Diskin carbon fiber! The bolster and pins are nickel aluminum bronze, not something you see much of
