Mereckons one should be able to get one built for $5. That's right. All you need are 2 voltages: AC and DC. DC etches the depth, AC deposits black.
So, next time you're at a flea market, pick up (they sell them for $1 most of the time) 2 "charger" power supplies - 12VDC and say 12VAC.
All you need now is a DPDT switch On-Off-On. To the 2 contacts in the iddle you attach 2 wires - one goes to the blade, another one to the pad.
To the "top" pair of contacts on the switch you attach 2 wires from AC power supply. To the bottom pair - 2 wires from DC power supply. Done .
If you want to get fancy, fashion a shoebox enclosure. Add a fuse.
To operate, flip the switch to DC and get some depth. Then flip to AC and deposit some black. Of course, make sure you get the polarity right when in DC mode (which wire from the 2 on the middle 2 contacts goes to the blade vs pad).
