Never used to cut anything but thin air
Received in late Aug, like new condition
Deuce II 430$ fixed What do you get when you take ZTs flagship chopper, The Deuce, and put it in a wind tunnel? The Deuce II. With a continuous curve blade geometry and slimmed down handle, The Deuce II has all the durability and raw chopping power of the original, but with sleek new lines and improved balance. This blade turns fluidly at the top of the lead hand, generating even more pop per chop. Like all ZT blades, the Deuce II is full tang, sharpened, sheathed and heat treated for business. Total Length 35.5in (.90m) Blade/Handle Length 23in/12.5in (.58m/.32m) Steel Width .204in (5.2mm)
Steel Type 5160 Weight 3lbs 5oz (1.5kg)
here for sell is a zombietools Apokatana
Received in aug, never used to cut anything but thin air
Apokatana 430$ fixed When vastly outnumbered by your enemies, every student of the art of war knows that speed, stealth, and smarts are all youve got. For the runnin and gunnin warrior who knows how to choose his battles and vigilantly maintain a corridor of retreat, ZT introduces the Apokatana 2012, our take on the tactical katana, and an update of our previous Apokatana design. With a blade of 28 inches, the Apokatana has the traditional dimensions of the time-tested Japanese blade, but with a touch more beef in the spine for durability and increased cutting momentum. The aluminum slab handle is wrapped in black leather for a comfortable, low-slip grip. When the Kydex sheath is strapped to your tactical vest or bag, the Apokatanas 3lbs will allow you to get in, cut down, and bug the hell out when Zaks numbers turn against you.
Total Length 39.5 in (1 m) Blade/Handle Length 28in/10.5in (.71m/.27m) Steel Width .204in (5.2mm)
Steel Type 5160 Weight 3lbs (1.36kg)
Not the best quality pictures, I know... If you really want, ill get some better shot of this one
not including shipping or paypall fees
Retired blade
Like new condition, used to cut thin air only
received in late Aug
the Spit 800$ At four feet long with two-foot double-edged blade and a chisel tip that pines to puncture, The Spit is the most versatile weapon weve yet added to the ZT arsenal. Modeled after the Iklwa (pronounced ick - wah), a weapon that forged the kingdom of the Zulus in southern Africa, The Spit has the length to keep the bitches at bay and the speed and flexibility you need in a multi-target brawl. Its a brutally effective slasher both forehand and back, delivers a piercing jab that can easily slip past ribs and into eye sockets, boasts a solid butt end for backswing bashing, and can even be chucked short distances in a pinch. Everyone whos handled this girl remarks on her light weight and ease of handling for a weapon of its size. Like all our blades, The Spit is one continuous piece of heat-treated 5160 spring steel sandwiched between slabs of T6 aluminum and wrapped in high quality Montana leather. Comes with Kydex sheath that can be rigged with a shoulder sling to comfortably carry like a rifle.
Total Length 48 in (1.2m) Blade/Handle Length 24in/24in (.61m/.61m) Steel Width 0.204in (.52cm)
Steel Type 5160 Weight 4lbs 10oz (2.1kg)
price is negociable a bit, will be put on ebay at 800$ if it doesnt sell here
