Cool! I know it won't be as significant as the 10xx or W2 but hey, can't hurt! Thanks.
Heat just the edge and quench, you'll get a line. Clay wont do much with 5160.
Here's two knives that both have 5160 blades. They were done pretty much as Don had mentioned except I tried something a little different. I brought both blades up to temp in my forge. As soon as I removed them from the forge I lit up ox/acd torch. As soon as the edge turned black I applied the torch just to the edge. As soon as it was the color I wanted I quenched the whole blade.
Raymond,
Did you bring the entire blade up to temp. to avoid a "heat sink" situation from the cooler spine? (Blade's edge just heated....spine drawing heat from edge)
Ray thats another way to get one more thermal cycle in plus some stress relief for good measure.
Bruce, The main reason I did it that way was to save acetylene plus its a little faster having the blade preheated.
You always have some good tricks up your sleeve....if you had sleeves![]()
