They definitely have chromium carbides not iron carbides.Where does the information come from that 13% Cr steels don't have much Cr carbide, but have iron carbide instead? When researching those types of steels a while ago, all the sources I found showed either Cr23C6 or Cr7C3.
Well, define quality. 5160 that is "fairly close" to 52100 in chemical composition is wildly out of spec. If you mean close to 52100 performance, I still find that hard to believe unless it's out of spec because that .4% difference in carbon is about the most important .4% for performance, everything after being carbide fodder. Even if it makes a knife that's superior to 5160 that is in spec, to me that's not quality.
I don't think AEB-L is magic. I think it's relatively poor wear resistance and excellent toughness line right up with the fact that it's nearly identical to 5160 in everything but chromium content, which being free chromium likely does little to reduce toughness. If it has any performance outside corrosion resistance that seems to exceed 5160, then I would say you're more than likely correct in that it's because it's made to a higher quality standard with tighter controls than most 5160.
When the first zombie shows up, I will have plenty of time to forge 5160 zombie decapitators. I'll wait until then to list those type blades.
A better carbon steel equivalent would be 52100 with its small volume of fine carbides. But AEB-L has harder chromium carbides for better edge retention and wear resistance.
A closer approximation of stainless 5160 would be something like 12C27M.
You have numbers comparing “lateral load toughness” for the two?I wish that were the case with regard to lateral load toughness!
An edge deforming is not due to poor toughness, but insufficient hardness or geometry.No numbers and my observation is not scientific, but I haven’t used my large 12c27 chopper since the edge deformed by 1/4” where my blades In s7 and 5169 sustained microscopic rolling.
Ok, I admit that was completely wrong in what I said. I will correct it. I was trying to oversimplify it and avoid the complex carbide types. In my head I inadvertantly mixed up cementite (Fe3C), which is iron carbide, with martensite which is a body centric structure of iron and carbon. Can't say how that happened. I should stop doing three things at a time anymore. My apology ..
I have a Mini cleaver that i use in my kitchen all the time i made from 5160. It slices quite well. It was flat ground to nearly a zero edge from spine to edge though.The only knife type that I would say it was not a good pick for is a fine slicer - kitchen knives, wood carving tools, etc.
Otherwise, it works for any general use knife like a hunter, and is great for rough use knives like choppers, camp knives, and bush swords.
I know that some people don't always take Ed Fowler seriously
He changes his mind frequently throughout even that book. As you say changing ones mind is not necessarily bad. In his articles many changes to heat treatment are presented along with amazing differences in properties (10x as many cuts!) but then later he presents another method and doesn't even include the former parameter that led to a 10x improvement. I can only conclude that the testing is not sufficiently controlled.Keep in mind that book is quite dated. People change their minds.
