- Nov 26, 2006
I am looking to buy a replacement for my trusty Becker BK9 and I don't know much about this metal. Edge retention, corrosion resistance and durability are all significant and any help is greatly appreciated.
I have 1 5160 fixed blade, and it is a tough steel that will take a VERY sharp edge, the main drawback I have experienced is it will rust in a blink if your not careful.
f I could afford it (or, rather, if my customers would pay for it) I would rather use 3V - much tougher, but still carbon steel.
You have toughness issues with 5160?
-Cliff
For a large knife or sword I would take 5160 over 3V. 5160 will spring when flexed, whereas 3V is tough, but not very springy. Thus where 5160 will spring, 3V will most likely bend or break. This is not an issue with shorter knives though.most of the bases covered here...so I'll just add mine
PROs
great impact strength (toughness)
not brittle (spring steel)
easy to sharpen and strop (polish) the edge
not as rust-prone as O-1, 1095 or L6 (lower carbon %)
can be "steeled" instead of stone-sharpened
CONs
edge-holding good, but not as great as higher-carbon steels...
more frequent sharpenings (compared to S30V, etc.)
better if used for longer blades
will rust, requires maintenance
Personally, I really like it....and use it a lot. But my reasons (as a knifemaker) are different...it's less expensive, easy to heat-treat, can be forged to shape, grinds, polishes and sharpens easily.
If I could afford it (or, rather, if my customers would pay for it) I would rather use 3V - much tougher, but still carbon steel. It costs about 8 times as much as 5160 does. ($25/lb. vs. $3/lb.) Also, it doesn't respond well to forging. But for stock removal is great.
