5160: where, how, when, why 2 Buy
Hey all I'm new to bladesmithing and was wondering where I should purchase and what to look for in a HIGH quality 5160. Also what size of bar stock, whether round or what and anything else you think a fresh newb ought to know that I haven't put into consideration. Forgive for my ignorance ok. Any and all advice and input will be welcomed and much appreciated. Thanks in advance.
If it helps I plan(or if all else fails have someone) to FORGE a 10" bowie-like campknife with a narrow tang, a 1/4" spine, a "soft back-draw" and with a differentially hardened edge.
In addition to Kelly Cupples and Aldo Bruno, check out Ray Kirk, rakerknives.com. I got 5160 from both Kelly and Ray. Aldo seems to be moving other steels lately.
As for stock, most of the demos I've seen have been using around a 1/4" flat bar about 1" to 1.5" wide. Some folks like to use heavier square or round in the 1" range and work it down, but, believe me, it is A LOT of work. Why 5160? For me it was because many folks lauded it as good AND easy. I have since learned that 1084 is, perhaps, an even better beginner's steel AND good.
Forge heat control, hammer and tong techniques, steel temp management, annealing, grinding/filing/finishing, heat treating, quenching, handles & fittings, etc... Lots of questions as you go along.
Good luck, Phil
Good luck, Phil
for a beginner, you cannot beat 1084. Aldo's 1084 currently comes in 1 1/2 by1/4, when hot the stuff moves like playdough, (don't try to work it cold) it is super easy to heat treat, it holds a good edge, and welds up beautifully. his price is good too.
-Page
I second Page's 1084 suggestion.
You haven't said what equipment you have available, but 5160 requires a short soak time in HT. 1084 just needs to get up to austenitization temperature and be quenched. Aldo has a very high grade 1084, designed for forging. He calls it 1084FG.
If you are going to draw the spine with a torch to get a differentially tempered blade, then 5160 will work. If you are going to clay coat the blade and do a differentially hardened blade, then 5160 won't work.
5160 is a deep hardening steel, 1084 is a shallow hardening steel. These terms mean nothing as far as how the blade turns out, but mean a lot in how the blade reacts during quench. 5160 was/is a recommended starter steel because of this factor. It is very forgiving of the HT not being done exactly right. Many new knifemakers will use old motor oil, ATF, or some mix of oils to quench the blade. With its deep hardening,5160 will harden in these slow ( and often poor ) oils. Its toughness and the slower hardening curve makes it a good steel to avoid cracking during quench and breaking the blade in use afterward. It will not form a hamon. It may show a temper line if the spine is drawn soft carefully while the edge is in a pan of water.
Now 1084 is often recommended because it is a better steel to learn on. The HT is still very simple, but it needs a real quench oil to get the max out of it.( It can be water quenched, but that takes a little practice to master.....and does have a failure risk) Now days, most new makers who set up forges buy some good out. New smiths now have read more, and learned more than the back yard blacksmith of old. Forums, especially this one, have given them access to much advise that was not available before,too. With a better understanding of what is happening in the steel, better HT equipment in use, and better oils, 1084 makes a superb blade with only a little more attention to quenching details than 5160. I you want a hamon, this is your starter steel.
Feel free to email me any questions.
Stacy
Shucks...that bit of information about 5160 not being able to be clay differentially hardened just shattered my world. Besides looking forward to the hamon, hardening with a blow torch doesn't seem natural and authentic. All my research into steel attributes for nothing.
Does someone know of a steel with similar attributes such as toughness, edge holding, not prone to chipping etc...such as you would want in a camp knife...that is common, not too expensive, relatively easy to work with, comes in virgin bar stock, and can be clay hardened? How about 52100 or L6? I rather be really good with a one or a couple of steels rather than be mediocre at alot.
Millie research W2 steel. Burt Foster uses 52100 but chooses W2 for a hamon, and can find little difference in the performance of either.
Get Aldo's 1084. I have been knife making for several years now and chose this steel to start forging with. W2 is great if you have a power hammer to get the round bars into a workable size but I don't know anywhere to get small diameter W2. 52100 is a great steel form what I have heard but it comes in the forum of bearings most times and would also be heard to get into easily forgeable sizes.
Get Aldo's 1084. I have been knife making for several years now and chose this styeel to start forging with. W2 is great if you have a power hammer to get the round bars into a workable size but I don't know anywhere to get small diameter W2. 52100 is a great steel form what I have heard but it comes in the forum of bearing most times and would also be heard to get into easily forgeable sizes.
OK...you guys have convinced me to go with 1084. The only problem is...WHERE DO I FIND HIM? I tried googling him but all I got was forums. Tried looking in supplies and tools but didn't know where to start.
Also how much is it going to set me back? And give me a size recommendation for the knife I descibed above.
If you've never forged a blade before and don't have someone to help you learn to forge I'm going to say you need to buy a lot of steel. There's a big difference in forging a nice 4" drop point hunter and forging a 10" camp/bowie. There's a lot to keeping stuff straight as you get a longer and longer blade.
Not trying to discourage you just pointing out something that seemed overlooked in all of the hoopla over what steel. What tools do you have? is your forge large enough to heat treat the blade and if not do you know how to bring a blade like that up to temps? (keep moving it through the forge ;) )
I'm looking for the toughest steel without sacrificing much in edge holding so is there much difference in that department between 1084 and the lower 10xx's in a diff hardened blade?
When you say tough, what are you talking about?
Steel is a tough material generaly speaking.
A good deal of any given knifes cutting ability is dependent upon its profile,thickness and basic shape.
Keeping this in mind, the shape the blade takes as it is ground is at least as important as the steel you use.
A badly designed knife made from O-1 or 1084 will be outcut by one designed and ground from a lesser steel.
When choosing a steel, do so by taking into account, what it is you want the steel to do. Chopping or slicing or filleting and the like.
Added to this the forging itself along with the heat treat is a major factor.
A factor, more important than which 10xx series steel that is used.
As is noted above 1084 is an excellent steel that is quite easy to process for someone with some good basic skills.
You will need some assistance with a knife of that size unless you have made a few of them.
Not trying to rain on your parade, but it is nice if you can accomplish what you set out to do.
Good luck with your project and keep us posted, Fred
I understand what you guys are trying to say. I just want to know how many rc 1050 or 1060 can be differentially hardened to.
Millie,
Kelly Cupples has 5160, 1065, 1080 and 1086 (1086 only in 1" sq.). For hamon and a hacker knife, 1065 would be hard to beat. To use 1084 for a hacker, a person is going to have to compensate for the higher carbon, (more carbon, more brittleness). Drawing back a little more (57-58 HRC), making sure the edge has a enough support, will help.
Kelly Cupples is a wonderful person to deal with and his prices are hard to beat. Use the e-mail address posted earlier and ask him to send you a current price list.
Mike
In response to a request for the why of this discussion, here is a simplified answer:
5160 is considered a high alloy steel. The alloy ingredients give it certain properties. The two that matter are the Chromium (the "5" in the name means that it is a high alloy chromium steel) and the manganese. There is approx. 1% of each, along with .60% carbon. These alloys allow the steel to be deep hardening and tough. When a steel is deep hardening the hardness goes deep into a large block or thickness of the steel. In a knife blade thickness,the hardness goes all the way through anyway, so it does not matter in this aspect one way or the other. What does matter is the rate at which the steel must be hardend, which is slower with deep hardening steels.
1084 is a simple steel, having just .84% carbon and 1% manganese. It is shallow hardening ( the manganese gives it just a bit of hardenability to make it a better steel). It hardens fairly fast. 1084 is considered the eutectoid steel. At .83% carbon, steel reaches the eutectic point. This is the lowest spot on the hardening curve. If the carbon is lower or higher, the temperature at which the steel converts to austenite gets higher.
Now, when steel is heated to its austenitization point (1520F for 5160 and 1500F for 1084), the arrangement of the atoms changes. Certain alloy ingredients go into solution ,too. This takes a little time, depending on how much alloy and what type. 5160 must be held at 1520F for about 5-10 minutes to allow this to happen. With 1084, there are few alloys, so there is no need to wait for them to go into solution. Furthermore, there is no excess of carbon or shortage of carbon. 83% is exactly the amount that is needed to tie up all the iron into nice little grains. Since you don't need to wait for excess carbon to form iron carbides, or a shortage of carbon to be evenly distributed, 1084 can be quenched as soon as it fully reaches 1500F.
Here is where it gets a little harder to understand:
If you look at the IT (isothermal transformation chart), TTT (time -temperature transformation chart) and the CCC (continuous cooling curve chart), you will see that 1084 crosses the pearlite nose ( around 1000F) in about one second. 5160 has five seconds to do it in. If either steel cools fast enough, it misses the nose and goes to martensite at the Ms (martensitic start point) which is between 400F and 500F). If it takes too long it becomes pearlite, or a mixture of structures. Martensite is the hard, but brittle structure that bladesmiths want for knives. Pearlite is the soft structure you want when sanding and grinding prior to HT. The martensite is tempered after HT to make it tougher, but it always is somewhat brittle. This is where certain of the alloy ingredients help out by adding toughness to the steel.
When doing a differentially hardened blade ,the blade spine is coated with a refractory clay. The part that is coated,cools slower. In 10XX steels the edge (uncoated) goes to martensite by cooling fast enough to miss the pearlite nose. The spine cools a few seconds slower, and becomes pearlite. The point where one stops and the other starts is the beautiful hamon.It takes a fast quenchant, like Parks #50 or water to cool 10XX steel fast enough to get the best from it.The problem with water is that it is almost too fast, and cracking may be a problem.
The cooling curve for 5160 is too slow to get a martensite/pearlite blade done this way. It all turns to martensite. Because of the much more leisurely rate of cooling, any quench oil will work for 5160.Specifically Parks AAA or a medium rate oil.
When you do a differential temper, the fully hardened (all martensite) blade is given a normal temper to the desired edge hardness and temper. Then the edge is set in a shallow pan of water (1/4" of water in a cookie sheet works perfect), and the spine is heated with a torch. The edge is kept in the water and rocked from tip to ricasso to keep the entire edge from going above 212F ( actually you just need to keep it below 450F). The spine is slowly heated to a higher temperature (650-700F) to make the martensite in that area have a much higher spring temper.This will create a softer springier spine and a harder edge. It will show a difference in the polish, but it is not anything as distinct as a hamon. What you see is called a temper line, and shows the difference in hardness mostly. A true hamon shows two different steel structures.
Another method of getting a dual structure blade is to edge quench the blade after austenitization. It involves just quenching the edge in a quenchant and letting the spine cool in air. This gets a martensitic edge and a pearlitic spine.....but at a cost of great stresses and unpredictable hardness results. Many old timers swear by this method. Many metallurgists swear at this method. While it still persists as an option, it is a more advanced technique than a beginner should try....and to be frank, gets mediocre results anyway.
So, the breakdown :
5160 makes a good and very tough blade that can be differentially tempered to make a superb camp knife.
1084 makes a great and fairly tough blade that can be clay coated to attain a lovely hamon.
5160 is very forgiving in HT and can be quenched in most anything that resembles oil.
1084 requires a fast oil or water.
5160 finishes to a somewhat blah appearance.
1084 finishes (with hamon) to a stunning effect (just look at any good katana).
5160 forges fairly easily, but must be kept between 1600F and 2200F
1084 forges very well and is kept between 1500F and 2100F
5160 and 1084 are both cheap and readily available.
5160 is an excellent choice for differential temper
1084 is a good choice for differential hardening
Hope this short course helped.
Stacy
Stacy, great post but I doubt he's going to read it all... I hope that's something you just cut and pasted.
I read it all,and as a beginner,I wanted to say thanks!
Still just getting started forging and found that information very helpful.
