Case hardened steel is only hard on the outside. It does not contain carbon which is what makes a steel able to be heat treated into a blade. Once you grind or heat the case hardened steel it is no longer able to be rehardened.. Hope that helps !!
How in the hell do ya harden the outside layer of steel! I know your laughing at me!
You cover it with a case hardening powder and heat it, or put it in a carbon rich atmosphere and heat it . The carbon penetrates the outer skin a small depth, creating a high carbon surface (hard) with a low carbon core (softer). Heat it up again, or grind into it, and it is all soft steel.
Stacy
