6 inch fighter
Feedback: +27 / =0 / -0
a loveless styled fighter in cpm154
the mirror finished blade is 3/16 thick and 6.25 long with rounded spine and double hollow grind (back edge not sharpened )
the grind is started with a 10 inch wheel and then thinned out even more on a 6 inch wheel
the tang is hidden and the guard, pins and tapered frame are 304 SS
the scales are stabilized ceder burl
the deer lined leather sheath is from southpaw leatherworks
shipped price in the CONUS 700$
That is a sweet knife! :thumbup::eek: But help me with this:
"the tang is hidden and the guard, pins and tapered frame are 304 SS "
Help me understand what this is, and the advantage of it. :confused:
Thanks!
its just a different kind of build and allows a nice look while having a full tang that is tapered but a guard
it was also to help me get the tricks of the frame handle takedowns in my head (i just didnt want to mess with screws to make it a take down)
Do you have any in process pictures that you can share? I am still missing your explanation. It is early however, and my coffee is still brewing. :D
Maybe J.R. Cook's Constructing a Frame Handle is in the ball park of what he did?
http://www.americanbladesmith.com/uploads/file/Techniques Master Class/Frame Handles - Cook.pdf
By-the-way, superbly done Butch!!!
thats alot like i did sept i uses a brazed in nut and floating bolt to tighten up the frame to the guard (made fitting the frame to the guard a snap as i coiuld take off and ajust really easy
after i have all fitted up i MIGed things so they could not loosen then fitted the scales
