I think I can help. I just made a small neck knife from the stuff, and its pretty cool. First off probably some 95% of NiTinol is used for its shape memory properties not its hardness or wear properties, so most of the literature is written about that. The SM-100 is essentially a PM 60NiTinol which meanes 60 wt% Ni, and 40 wt% Ti. 60NiTinol can exhibit shape memory capability, and very high hardness, just not at the same time. The heat treatment required to obtain these properties is different, so say goodbye to a super hard supperelastic knife. I think this might be where the confusion with the low youngs modulus comes from; I think the youngs modulus is reported for the unhardened state, because that is what 95% of people use.
The heat treatment for SM-100 is 1800 F for 30 min and a oil quench. I was able to obtain 59 HRc, but I quenched in the foil packet, and might have been a tad slow. Next time I will still leave the blade in the foil packet, but I will quench in water. The hardening mechanism for this material is the precipitation of TiNi3. While I have no data on edge retention, this makes me think that it is fairly favorable because it is hard, and full of very hard TiNi3 particles
As others have stated this material is absolutely corrosion proof. The only thing that will touch it is Hydrflouric acid. For a small neck knife that I plan on never taking off this is a must. Also it is slightly lighter than steel, another plus for a neck knife. Additionally NiTiNol will anodize somewhat. Some people are getting some awesome oxide patterns out of heat treat.
