Perhaps
But one thing I look at is how quickly (how far back from the very edge) the blade stock reaches 2mm-thick as a measure of how much the blade must force apart the cutting medium to make deep penetration (as is required in tough materials like wood). Since most Mora
stock is only 2mm thickness, that gives them the advantage that once the bevel has split the medium 2mm wide, the blade can slide through vs. most other knives which feature a primary bevel which continues to widen. To improve slicing ability of these thicker blades, the edge needs to be much thinner than the Mora which can be left at even 45-inclusive (very robust) and match them... again, this is on specific materials where deep penetration is required. On paper & rope, etc. that separates immediately upon being cut, the thinner & more polished edge (vs. stock) wins both in cutting efficiency and edge-retention (assuming steels of similar performance). I don't do much slicing of thermal paper and the like, I'm looking at wood and meat, etc. For me, a robust polished edge on a thin blade means excellent slicing that endures. :thumbup:
Doesn't the same hold true for machetes (your forte)? Put a sharp but robust edge on a very thin stock for a tool that will slice away at tough materials all day long (though obviously not designed for chopping wood where it may bind and bend)?
(btw, I haven't sprung for that Condor-Viking yet, other expenditures got in the way, but you
will be taking my money for one at some point here...
