Hello all,
I've done enough forging in my 55 gal drum wood burner that I'm truly fed up with spending as much time fire tending as bladesmithing...
I'm looking to make a small forge with efficiency as the primary goal. I've read a ton on design but most threads/WIPs are older and in places where fuel cost do not seem like a concern.
Current plan is "2 ceramic fiber, refractory and ITC 100. One of the other joys of living in Hawaii (I don't deserve any sympathy
) besides high fuel cost is shipping cost. Does the type/brand blanket & refractory really matter? I can get CeramaFiber 8# 2300 degree fiber with free shipping vs $100 shipping on Inswool from Hi Temp Tools.
Inside forge dimensions are my next question. I have a 8" by 24" old air tank off of a truck which will make a nice solid shell and bring me to about 3 1/2" inner diameter assuming 2 inch blanket plus coating. That seems like a good size but could/should I go a little smaller? Blades probably wont be any bigger than 1.5 wide.
I've read mixed opinions on depth. Seems about 12 inches is pretty common but lots of people say you're probably not working that much of the piece in one heat anyway so a smaller pass through forge may be advantageous. If this was specifically set up for forging and not doing any heat treat how deep would you make it?
Thanks for the input
