- Jul 8, 2008
OAL- 12 5/8"
blade- 8" long, .087" thick at the spine, .021" measured 1/4" behind the edge, and .009" thick at the shoulder of the edge. 2" wide -------I have come to find that the 1/4" back from the edge measurement is the most important one. you can fiddle with the shoulder of the edge measurement to make it say what you want {by changing the sharpening angle}, but 1/4" back from the edge is 1/4" back from the edge no matter what, and really tells you how much steel you will be pushing through whatever it is you are cutting.
steel- 1095 high carbon, differentially hardened. heat treat includes a double normalize, double anneal, triple edge quench and triple temper for a really nice performing blade that takes and holds a great edge and yet is easy to resharpen!
grind- a full flat grind, sharpened on a Smiths 325 diamond hone with micro bevels, to an agressive razor edge
finish- 400 grit machine finish on the bevels under scotchbrite belt finish
handle- Tulipwood, with brass corby bolts. handle is finished with 200 grit with the lines running across the handle so it looks good yet isn't slick
sheath- no sheath on these, but I can make one if needed for an extra $30.
the tests below were on the first ones of my 1095 kitchen knife line. They are a good representation of this line, of course they will vary from parers to the chefs types, but give a good baseline for the performance you can expect.
"I haven't come up with a standard of tests for kitchen knives yet, but I did test this one out on a 1/2" manila rope that I use on my hunters. this is very coarse and abrasive rope that is very hard on an edge. this knife went 101 cuts on the rope before it required a 2 pound gain in force to complete each cut. the first cut required 14 pounds, and the 101th cut took 16 pounds on my cutting board scale {14 pounds includes the weight of the cutting board, the rope, and the weight of my hand to hold the rope}. It also passed several edge flexes on the brass rod test. she fell through carrots and potatoes, cut straight to the board, with very little pressure, Im going to have to make me one of these now!"
the prototype of this knife design did very close to the same in cutting performance, and then after we cooked lunch with it to check performance in the kitchen, we cut more rope, did 12 edge flexes on each side with no chipping or rolling, and then clamped her in a vise and she did 4- 90 degree flexes { 2 in each direction, I cant tell how many foot pounds of torque were required as my torque wrench is set for narrow tang hunters and couldn't attach it to the handle} without breaking or the edge cracking. after the last flex, I straightened her out, put on a Bocote handle, and she now resides in my kitchen knife block.
$215 plus $15 for shiping/insurance to CONUS. I can accept paypal Joe357m@bresnan.net or money order.
1st to post "I'll take it" gets it!!!
Ships within 48 hours of payment priority with ins.
Feedback appreciated, and thanks for looking!
If you would like one like this one or different, PM or email with details!
