- May 18, 2019
Did you protect steel when you do normalizing cycles ? 40 min on high temperature , there are lot of decarb.............?
My SOP is stainless steel foil wrap
Weird , 80CRV2 will harden quenched in whatever oil ,heated with torch ??I was testing the hardness on a completely clean steel surface.
Shine clean steel does not mean that you have passed decarb. layer ...something similar happened to me with 52100 . I forgot it was quenched -HT many times .i was doing some tests ..........so I have very deep decarb. layer before I reached to hard steel under ?
Can you drill holes through it? The few times I didn't think it hardened, it was plenty hard under the thick layer of decarb.
You should make some spark test to see if it is carbon steel ...........
Pop's Knife Supply for 8670. Supposed to be tougher than 80crv2. I haven't heavily tested it yet but it grinds and drills real easy.
We have gotten W2 from customers from NJSB and we can’t get it to harden. But a customer also should not have to pay double or Tripoli heat treating cost to fix the mistake of the seller.Just to add, I had trouble with aldos W2 a while back as well and it took me cycling at something like 1750 for a few cycles and then a few lower cycles to reduce grain back to a reasonable size to get it to harden.
I agree, and I'm not nearly as large a customer as you probably were for NJSB but they also told me that the issue was my fault and to pound sand. I took my business to AKS and PopsWe have gotten W2 from customers from NJSB and we can’t get it to harden. But a customer also should not have to pay double or Tripoli heat treating cost to fix the mistake of the seller.
Then there must be a reason why it will not harden ????? Maybe to small grain ? Heat that MF to 2000 Ftried it
sparks like carbon. Not super high, but enough flowering I’m sure it’s not mild steel
When the grain size approach sub-micron sizes, some materials may however become softer. This is simply an effect of another deformation mechanism that becomes easier, i.e. grain boundary sliding. At this point, all dislocation related hardening mechanisms become irrelevant.
What heat lot was your steel from. I only buy steel from one lot and it’s been ok.tried it
Your receipt should say what lot its fromI have no idea how I would be able to tell what heat lot its from. I'm not even sure what a heat lot is, although I can guess.
I thought you said you didnt buy steel from NJSB...
