- Oct 19, 2009
I feel that WC would be chip-resistant enough for many normal uses, and at the same time it would far surpass most steels (if not all steels) in terms of edge-holding.
I would expect that it would far surpass most steel in edge holding in abrasive applications when used in light duty cutting or at a more obtuse edge angles than could be done in steel.
There are three primary mechanisms where an edge dulls.
1. Wear such as abrasive wear and adhesive wear (carbide would do well here)
2. Gross edge damage such as chipping, rolling and tearing (carbide would do poorly here)
3. Chemical, where an edge erodes due to corrosion (carbide would do fair here)
Carbide is difficult to sharpen by hand, even on diamond stones, because it is not ductile. So a fine edge tends to crumble away rather than get super sharp.
For these reasons, I think you will find it difficult to find a material that combines hardness, toughness and ease of sharpening better than steel.
I was watching the cutting competition at Blade last weekend and I wondered if tungsten carbide could play a roll in the competition knives. Not as the cutting edge (too brittle), but as the spine. The edges on these knives are very thin, but the spines are very thick, but the same stiffness and weight could be done with carbide in a thinner section and thus perhaps cut better?
Nathan I chose CF because it was so stiff, it is much stiffer than titanium, but less stiff than TC.
http://www.bladeforums.com/forums/showthread.php/855115-Advantages-disadvantages-of-a-1-sided-bevel.Another bonus, since the blades are chisel sharpened, they are inherently twice as sharp as a double bevelled edge.
