8670 heat treat
rodriguez7
Gila wilderness knife works
Im making a nice backpacking chopper out of this steel, and looking for extreme durability. Should I just use the standard 1500/400 with this steel? What kind of soak times? I’m heat treating it in an atlas mini forge. So I can only get somewhat close, not exact. I have parks 50 and canola, which would be best? Thanks.
You sure can use 1500/400. I prefer 1525f, 10 minute soak total (probably closer to an 7-8 minute soak, somewhat harder to do in a forge tho), and 130f canola. P50 is technically too fast for this alloy, but certainly doable. I am pleased with how stable this steel is in oil quench...no warping issues (as of yet). Very clean steel, too. Polishes beautifully. Very very tough even at high hardness (62+ 350f tempers)
Sweet, thanks for the replies. Don, you heat to non magnetic, then quench? With no soak?
Nice, I’ll give it a shot. Have you tested any blades to failure?
Yes, have broke a couple, tough & very fine grain. I had some edge damage on a cleaver, edge was just too thin for heavy chopping at high hardness. Ground the edge back a bit and tempered at 425, no more damage chopping fossil walrus & antler.
Only you would have enough scraps of walrus laying around to use it for testing knives lol
