Richard338
- May 3, 2005
I got mine last Saturday... long story short an electrician is coming tomorrow...
I snagged the KMG table and rest for my disk sander and boy does it not work worth a fuckkkkkk
A couple years ago I purchased the pheer 1 h.p. and a KMG workrest. Thing is a tank. If you go this route call pheer after your order to make sure the right face plate is shipped on the motor to match the KMG workrest.
I just remembered, it really helps to keep one of the lever-locks loose (one that locks the table's angle at the front of the arms) when putting the work rest back on the disc. This lets one of the arms slide side to side which allows it to insert easily into the socket without getting stuck, while the other arm remaining locked keeps the table at its set angle.
~Paul
My Youtube Channel
... (Some older vids of some of the older knives I made)
I cannot for the life of me figure it out, I still have to build another bench for it - so it's not hard mounted just yet, but it's pissing me off lol. I have a small table that was an old desk that I used to set all my grinder attachments on and my dunk bucket, but I need to build another solid work bench.
So I have a Grizzly G0864 variable speed 1x30 belt/ 6" disk sander and I did the simplest of mods to it yesterday which makes the disk sander 100x's more useful for me. I cut a 1" piece of the shroud off right at the table. I plan to do the other side and also clean it up a little better too.
So my question is this, should one of these larger pro style disk sanders be near the top of my shop list as I transition from doing slip joint mods to learning and eventually doing slip joint making? If so what would the benefit be to upgrading? I should also mention the disk speed on my Grizzly is from 2000 - 3400 rpm. Thanks!
I hear ya man, it's never fun having problems with a pricey new piece of equipment.
What specifically is giving you issues on it? Is it the ease (or lack thereof) of sliding the arms in and out, or is it something else?
Got any pics of the part that's giving you trouble?
Edit: did it come to you completely disassembled?
~Paul
My Youtube Channel
