- Dec 3, 1999
I built a new stand for my disc sander/controller... when I put it all back together I noticed my disc wasn't running true.
I set up a dial indicator on the motor to see if I could pin-point the problem (much like zeroing a 4 jaw chuck on a lathe). The motor shaft and perimeter of the disc look good.
But on the face/backside it was 0.020" out at the same point as the set screw. Just to see what it would do, I slipped a tiny shim on the opposite side of the shaft.
It got me within 0.010" on the set screw side.
What do I need to do to it to get it dead nuts on????? It's a Frink CNC machined disc, so I know it's not a problem of a cheap disc.
I didn't have any shim in there before, and didn't have any problems. Is it a problem with the key?
Any help would be appreciated!
THANKS!
EDITED TO ADD: I thought about adding another set screw exactly opposite of the one that's in it, but don't want to cut into that disc at all if I don't need to.
THANKS!
