I personally recommend facing it with 1/16" thick "Felpro" cork gasket material you can get from NAPA.
Pros: -No chatter like you sometimes get without a backing.
-If you use 9x11 sheets, they will last MUCH longer with the backing
-Smoother/finer finishes than with the same grit paper and no backing
Cons: -Its something that will require replacement from time to time.
-Depending on what you use to attach it, it can be a real job to get the old cork off for replacing.
Here's what I recommend: Clean the disc well with acetone or brake cleaner. Use something good like 3M spray adhesive to attach the cork to the disc. I just glued on a rectangular piece, then used a razor knife to trim it to match the disc.
For gluing the paper to the disc, I use the elcheapo Duro brand spray glue you can get a Walmart. One coat on the cork will usually last me 2-3 days of taking paper on and off. Its just tacky enough that you can press a new sheet of paper on, and trim the sheet with a razor knife, then when you need a new sheet or grit, you can peel the old one off fairly easy and apply the new sheet, trim, and go.
I've been doing the cork backing on mine since last fall, and have had to change the cork once...but that was because I got careless and caught the edge of a blade...it dug into the cork and ripped a chunk out.
When I purchased the material at NAPA, it came in a roll, which has enough material for 3-4 applications....and it was only about $9.
