Thanks to everyone who helped me out on my last 940 post, but I've got a new concern about this knife.
I've heard that it doesn't cut well - that the blade is more of a wedge and it isn't a great slicer. Is this true? How well does it cut?
the blade is not very tall from spine to edge. I prefer full flat ground blades with somewhat tall spine to edge dimensions.
Not at all a fan of the cutting performance of the 940 series. Owned several, could never manage to justify holding on to one. A PM2, with a blade ground from stock that is one and a half times as thick (.12 vs .18) outperforms the 940 in almost every regard. In the same blade and stock width, the Spyderco Mantra 2 is a SIGNIFICANTLY better slicer. I want to like the 940, but I just can't get behind the saber grind, and most are thicker behind the edge than I'd like. Even my Ritter mini grip outperformed the 940-1- and with a stock bevel, to boot! The 940 series isn't bad, mind you, you can put an amazing edge on them, but it's not a capable slicer when compared to just about any other knife of its size or stock.
Mind you, I'm of the philosophy that .12 stock is overkill for an everyday user.
Id say that's user dependent
If it's not slicing to your liking then reprofile the edge.
I've actually considered doing that, to make a modern cut more like one of my traditionals, but I figure I should spend more time building skill on the grinder first.
Hahaha,
I'm not sure one could call what I do "skill". More like fooling around with a magic marker, a bench grinder (with a white wheel THAT IS KILLER IMPORTANT), a diamond file and a Shapton 120 stone.
God that Shapton is brilliant !
yah what I do is so slooooooooow it is hard to make a mistake. More like marathon grinding. You know how in the movies about boot camp where they make the poor slob clean the floor with a tooth brush ? yah kinda like that.
I aM impressed with the guys who can go over to a real belt grinder and do it all in a couple passes.
