- Feb 3, 1999
Guys
Some observations.
First off, to streamline this posting, I propose a new term for the different generations on Commanders. As I dubbed the "Old" and "New" Styles, I hear by change it to "First Generation" and "Second Generation". Sounds so much more professional, doesn't it?
It seems to me that the First Generation Commanders have taken on a life of their own. We may be seeing the birth of the first cult status EKI Production knife.
I've received several emails in the last three days asking among other things, what I thought a First Generation Commander would go for on the secondary market.
"Secondary market for a production knife?!"
Well . . . I . . well . . . . it does make one think. There are a limited number of them (supply is low) and there are people looking for them (aka demand). That's the makings for a Secondary Market alright.
I bring this out publicly only because I have just about given up on getting another here on-line. I think if people are going to find them, they will have to hunt local Gun/Knife shows and Gun/Knife shops.
What exactly separated a "First Generation" Commander from a "Second Generation" Commander.
The First Generation Commanders bodies are thicker. The G10 scales and Ti liners are noticeably thinner on Second Gen Commanders.
I measured the bodies of a few Emersons I had on hand and came up with these numbers:
.49 CQC7B Waved
.49 Second Generation Commander
.51 SOCFK
.51 SARK
.55 First Generation Commander
.55 ES1-M
.56 Commander Proto
The thickness for the SOCFK and SARK kind of surprised me, I thought they would be the same as the CQC7B and Second Gen Commander It was interesting also that the Proto Commander was thickest of them all, even thicker then an ES1-M.
The blades and liners of the First Generation Commanders were water cut, as opposed to the current laser cutting. Really a small detail, but I prefer the "rounder" lines to the precision, laser cut corners.
A secondary detent arm was cut into the liner opposite the liner that formed the lock on Second Generation Commanders.
On the spine of the Second Generation body, just shy of the thumb ramp, the liners are serrated. This change I like. (This and the secondary detent are the easiest ways to tell a First Generation from a Second Generation)
Up until very recently, EKI was grinding the tip of the Second Generation blades at an angle. This allowed the blade to retain it's thickness almost all the way out to the tip. recently EKI went back to the First Generation blade grind.
Here is some more information I've been giving out about the First Generation Commanders. None of it is solid or at this time, 100% verifiable.
1. My understanding is that the first 1000 Commanders were serialized.
2. The transition to Second Generation was made sometime in '99. All '98 Commanders are First Generation, some '99s are Second Generation.
3. I have never seen a '99 with a serial number and have never seen a '98 without one.
4. All the Satin Commanders I have seen from '98 are real Satin blades (uncoated). All these have had serial numbers under 200.
5. Most of the '98 Commanders are plain edged.
Again, this information is sketchy at best. Based solely on my observations I'm no expert, just a consumer and collector.
If anyone has better or different information, let's hear it. We all can learn something here.
hth
John
[This message has been edited by John Hollister (edited 01-03-2001).]
Some observations.
.49 CQC7B Waved
.51 SOCFK
.51 SARK
.55 ES1-M
.56 Commander Proto
hth
John
