Cliff Stamp
BANNED
- Oct 5, 1998
Satrang said:A two point spread is the best you can offer due to the accuracy of the test blocks used to calibrate the machines.
There are sets of calibration blocks from NIST available which are very precise, they note for example changes of 0.2 HRC in calibration readings compared to blocks from independent sources (even different countries) which have no strict regulatory control (this is on the lower end of the HRC scale for knives, the change is larger for the upper end where most knives are hardened).
NIST of course is pretty much designed for that kind of control being a standards organization. As noted, that kind of very coarse HRC reading allows the steel's properties to change by a significant amount, 70% or more in regards to toughness for example. So it would be more informative to give the actual goal hardness and a tolerance, though you could infer it to be maybe midrage assuming standard form.
Of course it isn't only BR which does this and many companies don't even give hardness readings, ideally they would say how they are doing the hardening which would be informative to the user, but of course there are issues with that as well, specifically competition.
-Cliff
