- Mar 7, 2003
If A2 stock is very thin stock like 3/32 or 1/16 I have learned to air quench it. It often warps in plate quenching if it's thinner than 1/8.
Thanks Leu. I was thinking of something along the lines of what you make, with the single chisel grind with no secondary bevel. Man that would take a while to finish if you had to leave it at 1/32" before heat treating.
Thanks for the replies and the A-2 specs provided. The comment about thin blades warping raises a new question.
What good is plate quenching A-2 if it may increaese the chance of warpage with thin blades. I thought plate quenching would help prevent warpage. (I already bought some plates)
Is it mainly to speed up the quench so you can get to tempering faster? My understanding is that A-2 and D-2 are alloyed so they will harden to 63 or 64 in still air. Is that not always the case? If you get an extra point or two of hardness with plate quenching or cryo, wouldn't a 500 degree temper bring it down to 60 rc in the end anyway?
I also have an unrelated question, if I may mooch a little more time from anyone.
If I foil wrap my blades, can I put them in my kiln cold and bring it up to the preheat temp? Is there any harm in this? It seems to me that opening the door to put them in after it has been heated would just cause loss of heat and extend the time in the kiln. Thanks.
Gerry Hamrick
Snohomish, WA
There's a toughness peak at 500 F which will give you 60 HRc, so that's where you go !
A2 peaks at 41 lbs at 55 and 60 HRC and drops off in between.
At HRC 58 the Charpy C -notch test for A2 drops to between 29 and 33 lbs (per Crucible Data Sheet).
