- Oct 2, 2006
A2 responds very well to plate quenching.
What is plate quenching?
Instead of quenching in an oil or water, you place the blade between two pieces of heat sink (in my case -and I suspect for most everyone else- that happens to be two big pieces of aluminum plate). The plates draw the heat out of the steel, and voila! you've quenched the blade. My plates are 1" x 8" x 18", and the process is extremely involved, and very difficult:
1- Heat blade (in heat treating foil packet) to recommended austenitization temp.
2- Grab foil packet (with blade in it) with tongs.
3- Put "side down" on bottom plate (usually on floor of shop).
4- Put top plate on blade, making a 'blade sandwich'.
5- Step on top plate to make good contact between plates and blade.
6- Count to 20 (or 50, or say the alphabet a few times out loud, or sing the name game song for three names, maybe recite a few lines from Monty Python's Holy Grail - you get the idea).
Take out of foil packet, and start your first tempering cycle.
Thanks, this trick should be useful. Seems really quick as well, would it cause cracking for thinner blades?
No. But what you could end up with is a pretty severe WARP depending on how you ground out the blade - evenly or not. Stress relieved it or not, etc etc
make sure your folds/crimps are not thicker than the actual blade itself, otherwise that will cause issues as there won't be total contact.
In or out of the wrap?
Warping? But it'll be in between two aluminum plates to keep the blade flat, no?![]()
