A2 will be tougher and also hold an edge longer than 154cm.
In what fantasy world will that happen?
A2 is tougher, great steel for larger knives that will see rough use.....
But there is no way it will hold an edge longer than 154CM.... The alloy content just isn't there for that to happen...
Both steel has very similar carbon content, at the same hardness the lower chromium in A2 will likely to produce the more complete plate martensite structure while the high chromium steel like 154cm will have much more chromium carbide and also the remained chromium both will have a negative influence on the strength and toughness of steel structure. Beside wear resistance, strength and toughness is the fundamental of edge retention, it is actually the durability of the smallest part of the edge. You also need to know the fact than the higher alloy steel will suffer more about the retained austenite problem, the method like cryo can just reduce but can not completely eliminate it.
This is the reason why the lower alloy steel like W2 or 52100 can perform better as a knife blade than many other stainless with much higher alloy. The word edge retention is not as simple as you said. Lower alloy = lower edge retention is just a plain misunderstanding.
English is not my first language so its quite hard for me to explain anything metallurgy.
Most of the A2 I have used has given me probably the lowest performance in the edge retention category
LOL! wut?
ajajajajajajajajaja
Sorry duders, but A2 is very tough and has excellent edge retention. Period. Real world usage proven.
Alloy content? Who gives a damn about that? What difference does it make in this case? All the alloy content of 154CM does is make it more stainless, not make it hold an edge longer.
I have used A2 head to head with 154CM and tons of other steels and not many of them can hold a candle to A2. Ya know, there's a reason Busse used A2 exclusively before they switched to INFI. It is that good. A looooong while back I had an original straight handled steel heart in A2 and it was an excellent knife in every respect. I never should have sold it.
