savagesicslayer
- May 24, 2005
I just bought a Maxpedition gearslinger the other day the model I bought is the LUNADA.The specs and details:
Main compartment: 12" x 8" x 3" slightly tapered towards the top, front and back divider, internal loop field for CCW, inner organizer pocket, YKK#10 zipper closure, drainage grommet
Front upper pocket: 7" x 3" x 1" with divider and elastic organizer loops
Front lower pocket: 8 x 7 x 1.5 with divider, elastic organizer loops, key retention, and drainage grommet
Front slip pocket: 6.5" x 5.5", YKK zipper closure
Rear pocket: 6" x 8" with internal loop field for CCW, button closure
Modular webbing: 2 rows x 4 channels in front, 4 rows x 2 channels on both sides, 2 sets of 2 rows on shoulder strap.
Belt loop: Hook-and-loop flap style, non-slip texture, accommodates up to 2.5" wide belt
Shoulder strap: Ambidextrous. Integral with 2" webbing and Duraflex Warrior side-release buckle, can be concealed in rear compartment
Cross strap: Ambidextrous. Adjustable in length. Made from 0.75 webbing with built-in survival whistle side release buckle
Handle: 1" webbing with cushion and Duraflex D-rings for optional shoulder strap
Approximate overall volume: 390 cu. in.
Empty weight: 1 lb, 10 oz
(courtesy of maxpedition's site)
I bought it as a day hiking pack/BOB.
Now my first impressions of the pack were "wow that's freakin small!"but I didn't crap on it I decided to put it to the packed gear test.
I unpacked my old mil-spec pack and set to loading the gearslinger.To my utter surprise it started fitting gear far better than i even thought:
I attached my spec-ops survival sheath to the side with short malice clips to some of the many(and I mean many) malice clip attachment points.On the other side I attached another Maxpedition product the ROLLYPOLY.A folding pouch that attaches to malice clip points.It almost doubled the pack space instantly.The features and attachments are almost limitless with these type of packs.
after I filled it with all kinds of outdoorsey things I put it on.After I adjusted the Main strap and hooked the secondary retaining strap I found it to be very comfortable and secure.The main strap it switchable from left to right and so it the smaller retaining strap so either left handed of right handed wearers should find it comfortable.The thick pads are covered with a sort of traction webbing to aid in holding the pack in place while in motion.There is also a belt loop on the back for additional support.
Here's all the things that I put into this "little' pack:
I look forward to doing a lot of hiking and camping with this pack in the upcoming months.
