- Apr 20, 2001
I get it, General. If you remove material from one side without removing enough material from the other, you end up with something resembling a mini-chisel grind.
So, if I understand you correctly, if it shaves better in one direction than the other, you need to remove material from the side that faces down (when shaving good). Or conversly, you need to remove material from the side facing up when it doesn't shave well. Is that right?
Essentially you are grinding away the "flat" side of the mini-chisel edge. Tell me if I've got it backwards.
