Well I'm beginning to assemble the first blade. I've decided that I will treat each blade differently. One will be finished so that the grain pattern is emphasized and one will be finished for the hamon. I've very recently learned that in low contrast, low alloy pattern welded steels, they each require very different methods. For the hamon, if you use too aggressive of an etchant then everything etches in a very similar way since you don't have the manganese and nickel to highlight differences. To show the hamon you have to use very light etchants.. vinegar versus ferric... and rely on the differences that emerge in scratch resistance between hard and soft steel. Traditional Japanese water stones are perfect for this. I don't have real ones, but I do have a couple synthetic.. an 800 and 1000. Normally when I clay quench a blade, I can do a quick grind to 220 and a quick etch. NOTHING shows at all with this stuff. So I had to do a machine polish to 600 and then go to an 800 water stone. You can immediately see a dark cloudy/scratchy area representing soft steel and a polished area showing hard steel.
The other blade will just be heavily etched to show the little bit of contrast between the W2, shear steel, and bloomery steel. In retrospect, I should have folded a couple more times because my pattern is showing quite a bit more bold than I thought it would.
Anyway... the first blade will sport copper habaki, copper seppa, wrought iron spacer and naturally featured American osage orange and have matching wooden scabbard.
The blade seen in that picture will be heavily etched to show the pattern... but the hamon is showing fairly well due to water stone treatment before etching. So the hamon will show.. but the fine details will be obscured.
I will wait until I get some finer abrasives to polish the hamon on the other blade.
