A Boucheron and sheath = Wild Goo 15
The thin (like the originals) 7 5/8" long blade is full-quenched out of 1095 is by Tai Goo. it was patterned after an original 18th Century French trade knife. I did the handle like many original replacement ghandles using a whitetail crown with a buffalo rawhide grip piece and hand-forged rose head iron pins - the sheath is rawhide and brain tan over bark tan decorated with beads and bangles ala the Plains Cree.....
Beautiful Chuck, Absolutely beautiful. Did you use the bluing and bleach etch on it? I really like the look of the blade.
I made a correction this is WG 14 not 15 - I just got #15's blade (a 10.5" Bowie) from Tai today and had that on my mind....
Yep that's my "standard" cold/blue bleach etch with a couple of adaptations - if you looke close at the blade edge near the tip you can see a faint almost "hamon" look - I got that by coating the whole length of the edge with laquer for a resist (Tai's blades are scary sharp and I didn't want to mess that up) - I etched it and then after cleaning off the resist I hand "polished" the whole blade to smooth out/round off the etch a bit (like an old, well used blade gets) and then carefully etched the resisted area lightly (all but the very edge, then polished lightly again. To polish I used red ocher mixed with olive oil and applied with a piece of leather in the way the old timers did...
Wow, my leather supplier showed me some rawhide and I thought how would I every make a sheath out of that. Both are impressive, thanks for sharing
The knife is really nice Chuck and that is one of the finest sheaths I've ever seen!!!!
I wish you would do a tutorial on making that style of sheath, especially applying the beads!!!
L6steel - Here's one I did that will get you started - just replace the rawhide liner with a vegtan one then cover with rawhide or braintan as you wish...
Building a Frontier Sheath
For doing beadwork - see http://www.nativetech.org/glasbead/glasbead.html
Also see their bibliography - some folks find beadwork tedious for me it is a way of relaxing.....
I use the applique and the lane stitch dependent on tribal style and period. I use the early style "pony" beads in size 8/0 (mostly) or 10/0 - I get my beads mostly from Crazy Crow....
For rawhide I prefer deer or elk (www.hideandfur.com or www.eidnesfurs.com) - cow makes good liners but is much "stiffer" than deer or elk for using as a cover.
