A couple forge questions.
These are dumb questions but I need to ask them so I can understand how to do this correctly. This forge will be a vertical forced air forge just so you know.
I am building the burner and forge off of recommendations by @Stacy E. Apelt - Bladesmith I think I understand everything but these few things.
1. What size hole do I need to drill in the forge body before welding the burner sleeve over it?
2. What size burner sleeve do I need?
3. Does the burner sleeve and the actual burner assembly need to be threaded that way you can just screw to burner into the sleeve? Of course I wouldn't seal that part or anything because I might want to use the burner in a different forge or something. I know the rest of the burner assembly need to be sealed up.
Sorry for the dumb questions. I know I'm probably over thinking this but…
Daniel.
