A couple more Blade 2010 pics
blgoode
Thought is post. Few more iPhone pictures. Got the one etched and 2 finish ground. Both have wd40 on em. Only took onenpicture of the non etched one.*
both are differentially heat treated 0-1
Ha Ha - Are you serious? This one will have red liner and black canvas micarta.
Glad you will be there!! Great putting faces with names :)
I am serious depending what $$ you're getting for these bad boys these days.
Red liners and Black canvas micarta w/a 'blasted' or 'rougher' finish would be perfect for this bad boy. However... if you were going to 'customize' this one then I'd opt for that great 'greenish' G11 and white liners to match the 'hunter' I picked up from you a year or so back. :) Ha...
Nope, unfortunately I won't be able to make Blade... but I HOPE in the near future to be able to attend.
This is a tad smaller than the TTW knife. It's meant to be packable in a "combat" setting where gear space is limited. It's about a 6.5" blade.
Email me your email addy so I can let you know what is available after the show.
My addy is blgoode @ bellsouth DOT net
Making some progress!! Here are the last 2 weekends I think.
Here is where 9 are at today.
Still have plenty more to work on :)
I always love your knives. Best blade and handle shapes around. You also leave a great finish on the blades that really shows the differential heat treat.
Thanks for the remarks friend!!! I apreciate that.
Brian, what kinda glue do you use that is all over those clamps?
Lookin good, btw. I'll see you at Blade for sure.
I have had good luck with 5ton epoxy. The prep I think is the key. I drill small angular holes in the handle scales and hope the glue acts like small claws to keep sclales tight. The few I have busted off have been a job to remove!!! Far from normal use would ever do. I would like to get acraglass too. Alot of glue debates in the shop area but I have had good success with fresh 60 grit surfaces+ tang holes + angled scale holes.
Here is my weekend effort. Off work Friday so I'll get the 4 sidekicks and the 3 D2 Grimlins to this stage and start glueing handles the weekend!!!
Take the shop clock and put it outside. When I am pushed for time, that damn thing gets louder and louder. Looking good! Best of luck and have a good time at the show.
Paul
your not finished yet. get on it. you going to have a bunch of sheaths to make
