- Jul 12, 2008
I bought the blade with rivets and a set of pre-shaped handles from bensbackwoods and I want to swap the brass Corby rivets with stainless ones. I also want to add a lanyard tube. I plan on buying the parts from knifekits.com (unless someone has a better suggestion). I have read several posts on this subject but I couldn't find this exact info. Please excuse me if these seem silly because I have never done this before.
Questions:
1. Does anyone know what dimensions the rivets need to be to fit this blade and scales? (Head Diameter X Step Diameter) I know the pin holes are 3/16". Would 1/4" X 3/16" be correct? I don't want to have to buy a step-drill to make the pins fit.
2. Would 1/4" lanyard tubing be correct? The hole in the blade is 1/4" and this is the obvious choice but I want to be sure before I order.
3. Does the lanyard tube need to be epoxied or is the fit tight enough that it can be hammered in with a mallet?
Thanks
Questions:
Thanks
