Hi guys,
Back again with some questions.
I have ordered some 01 steel, from a local supplier.
2 slabs, one 1/16" thick, 2" wide 38" long
one 3/32 thick, 2" wide 38" long
I did not want to order something thick but I think 1/16 is too thin and made a mistake ordering it. I wonder what size stock you guys order generally for a medium sized fixed blade knife.
I also noticed that the 1/16 thick slab is not completly straight, will that straighten out during the heat treat (the curve in it is ever so slight).
I figured I'd use some simple wood for handle material. Is there sometihng I could get from a non-knife supply specialist shop like Rona or Home Depot
for that ?
While at the handles, why would one put a liner between the handle and the thong of the knife ? Is it purely cosmetic or has practical purposes as well ?
Is it better to use bolts for the handles or a pin ? I would think a bolt would be sturdier and would allow handle disassembly, but again maybe that never happens and so it is not a consideration.
and last, I was thinking of using 120 grit paper at first on my disk grinder. I read it that 120 grit seems to be a good general grit. Woud that be ok or should I go for something finer for handle flattening ?
Thank you in advance.
Henrik
Montreal
for that ?
Henrik
Montreal
