A decade with my trusty Leatherman Wave
greetings and salutations fellow bladeforumites.
I'm a new member here and thought i'd make a contribution and share my experiences with the Leatherman Wave (henceforth reffered to as an LMW) which has been my constant companion for the last 10 years.
I am a professional photographer by trade and the range of weird little scenarios that pop up in my day to day work that can be solved by my simple LMW is staggering.
Seriously, in the 10 years i have owned this tool i have used it at least once a day for something (except for a 2 week period after i left it at a friends place and went stark raving bonkers without it)
I initially bought an LMW as a birthday present for a dear friend of mine (in 1999). after playing with it before handing it over, i decided i needed one too, so back to the shop i went and home i came with my own one.
General Impressions:
very, very comfortable grip on the pliers, the rounded handle edges are a lot more comfortable to use than the slim edges of the LM-SuperTool i also looked at.
ridiculously sharp plain and serrated blades (i sliced myself on day one).
scissors are far more durable and the spring is a far superior design to the scissors found on a Swiss Army Knife.
The one-handed action for deploying the main blades with the handles folded up is a far more practical design than the previous models where the blades were contained inside the handles and required the whole tool to be opened up to deploy a blade. also, i can use one hand to de-lock the blade and put it away.
A Look At The Tools:
1. The Pliers: As noted the pliers have a very comfortable grip. the needle noses of the pliers are grooved and offer excellent gripping properties. perhaps not quite up to par with a pair of dedicated pliers, but certainly more than strong enough for most tasks.
The pliers also come with a Wire Cutting blade at the base of the jaws, these simple wire cutters can cleave through tough 7mm fencing wire every bit as easily as my 9" Knipex dedicated cutters.
2. The Straight blade: with an edge length of about 3", this blade has copped an absolute beating over the years and has come through with shining colours. This is my preffered blade on the tool.
An idiot (not me) managed to snap off about 1mm of the point of the blade, a local knife wizard reground the blade for me and it's every bit as good as new.
The blade holds a great edge and a regular touch up with a diamond steel is all that is needed to keep it in tip-top trim. it has had only two proper "full" sharpens in 10 years.
3. The Serrated Blade: I admit i don't use this blade all that much. it will slice through even very thick rope like a machete through cheese and is great for slicing tomatoes while camping.
This blade still has it's factory edge, although next time my i have my blades sharpened, i'll have old'mate do a number here as well.
in all, an awesome blade that completely fills all my serrated edge desires (i'm a straight-edge blade kind of guy).
4. Hacksaw and file: believe it or don't, this blade actually gets a fair bit of use. i've used it to cut through galvanised chain, filed down irritating litttle bits of metal and on one memorable occasion, i had to do a quick resizing of a wedding ring five minutes before Aisle Time.
5. Wood saw blade: Double toothed, it's certainly sharp and will do the job on small items but you won't be chopping down any rivergums with it. Actually, this is the one blade on the whole tool i could happily do without. if you need a saw, carry a proper one.
That said, it has proven useful on a couple of occasions, but by and large it doesn't get deployed.
Ok, that's it for the four main blades and the central pliers. onto the secondary tools:
6. Scissors: awesome. simply awesome little gadgets these scissors. as noted above, the spring design is far superior to the springs found on an SAK. after the main blade, these would be the most used tool on my LMW.
7. Screwdrivers: being an older model, my LMW has four slot-head and one phillips head drivers. while perfectly functional, the downside is the drivers aren't aligned down the long axis of the tool. While this isn't a problem for small, quick jobs, i sure wouldn't want to use these screwdrivers in place of a proper set on a big job.
that said, they have certainly screwed-in and un-screwed plenty of screws in the last decade.
useful in a pinch, but not a proper substitute for a "real" screwdriver.
8. Can Opener: awesome. it's simple, functional and TOUGH.
9. Sheath: the leather pouch that came with the tool originally had a fine and served well until a couple of months ago when my border collie pup decided it was a chew-toy.
Fit and Finish:
My LMW has a few scratches and dents on it from all the abuse over the years, but then again, show me anything that's copped this kind of abuse that isn't a little scratched up.
it's very easy to maintain, just a scrub in some hot soapy water every couple of weeks and the occasional use of a little dry-lube every now and again is all mine has ever needed.
Conclusions:
both the LMWs i bought 10 years ago are still going strong. my friend loves the one i bought her and uses it regularly. my one is my constant companion and i feel rather lost without it.
it's not a replacement for a kitted out toolbox, but it can certainly deliver acceptable performance in a pinch in a wide variety of situations.
i would strongly reccomend an LMW to anyone. the newer model with it's exchangeable screw-driver socket looks very tempting, but suffers the problem of my model: it fails to deliver drive symmetry down the handle axis.
i have an overall dislike for folding knives, for any blade longer than the LMW's, i'd prefer a fixed blade over a folder. but, for an EDC blade with plenty of extras, the LMW is tough enough to take a beating and sharp enough to slice through most obstacles.
quite frankly, i believe the Leatherman Wave to one of the best things to ever come out of the USA. fabulous design, elegent simplicity and utterly functional.
Thanks for the review. A decade is good service. How are the serrations of the saws holding up compared to new?
thanks for reading it!
i rekon. when i bought it, i think it was about 80 pounds sterling. with the years of hassle-free, reliable service it has given me so far, the initial outlay seems so CHEAP!
given i havn't used the bush saw all that much, that blade is every bit as good as when it left the factory. the rest are all still perfectly serviceable.
How often do you service it? By servicing meaning cleaning, lube and sharpening.
i give it a washout every month or so unless i've been doing some particularly grubby work with it (when i wash it straight away).
i generally run the plain blade over a diamond steel about once or twice a week, again, if it's copped some seriously heavy work, i'll put the steel over it more often.
proper sharpens: done twice since new on the plain blade and once since new on the scissors.
lubing: oh wow, it's actually been about two years since i last put some dry-lube on it (i use that graphite based stuff). probably about time to do it again. don't lube these things with oil, grit gets into it and can gum up the action.
on that note: i should probably get myself the appropriate Torx driver and do a quick tighten of the major pivot screws. it's not that they are so loose the tool flops around, just there's a touch more play than when it was brand spankers.
Welcome to Bladeforums and thanks for a great review. You certainly know how to introduce yourself. :) I recently got a Wave to replace a Gerber MP600 and I really like it. It's good to read your review and know that I can expect many years of good service.
Great review. I too always have a Leatherman Wave on my belt at all times. There is not a day that passes where I don't use it at least once. I have a vintage Wave like you describe, but when the new one came out, and even though I wasn't thrilled with the factory sheath, I still couldn't resist. I bought one, and was immediately impressed that the main blade was a little wider. This eliminated the problem I had with the older model of shaving off a little thumb skin when opening the blade one handed. The tool is a little wider and a little heavier. After a while, I went back to my old Wave. I also have a Leatherman Super Tool that I carry when I'm hunting in the Minnesota north woods. A little less accessible, but a little bigger and sturdier for a survival situation. All are great tools that anyone would be proud to own.
I agree, sambo.
I have a Leatherman Wave I've been using for a dozen years or so. I'm pleased with it.
Great multi-tool.
(I'm also a professional photographer, by the way.)
Nice Review :thumbup: I Love Leatherman Products I have a original Leatherman that gets carried quite often.. I have been eye ballin a Charge and was curious what you think of it compared to the Wave? They look almost the same..
The Wave is a good tool, sorry I don't have mine anymore.
Gave mine to my son years ago, he moved to another city, didn't have any tools in his appt, and handed it over :(.
Well post some dagnab pics then! :thumbup:
Yours is one of those rare reviews that is actually meaningful. So many reviews consist of "I just received a Leatherman and can't wait to use it!". Your ability to use the same tool for years and years is quite impressive.
Hello Sambo - very nice review.
One question - have you broken those small pieces of steel(iside the handle) that guide pliers while closing? I belive it's only problem with LMW.
And one sugestion - get your LMW sharpened. Two sharpening over 10 years? And non for serrated edge? They HAVE to be dull now.
Another thing about serrated edge - it has VERY high angle. I don't know, maybe even a 40 degrees. Very durable serrations, but nowhere as sharp as spyderedge.
i don't believe so.
by "full sharpening" i meant: i took it to the local knife sharpening dude after my messing around with stones'n'steel failed to get it back to a razors edge.
and yes, it is time for me to fully sharpen it again.
seriously, i so rarely use that particular blade that the factory edge is still enough for it to slide straight through a couple of inches worth of rope when the need arises.
ask and ye shall receive!
hehe, thanx for that. it actually brought me up a little short when i realised "oh shite, i've been carrying this thing for a decade already"
Excellent review of a great multi-tool. According to Tactical Knives Jan 2010, the Wave is one of the most popular MT's amongst competitors in the IDITAROD.
After my original LM Wave got stolen, I hunted for over 3 years before I found another one. I now have 4 - 1 on my BOB, one rides in the car and the other 2, a BNIB 20th Anniversary original in black and a blister-packed 25th Anniversary, are safe queens. Hope Tim makes a 30th
honestly, i've never even handled a Charge model.
i have my Wave and, put simply, i see no reason to look at any other combo tool while my Wave is still perfectly serviceable.
that said, if you're in the market for a pliers based multitool, then i don't think you would ever go wrong with any Leatherman product. the build quality on mine, and the various ones friends have, is absolutely top notch.
After my original LM Wave got stolen...
awwwwwe man. that's pure suck right there. :grumpy:
i feel for you. sure, one LMW is much the same as the next one, but i've gotten rather attached to my LMW and losing it, or having some asstard nick it, would distress me greatly.
take heart, for there is a special place in Hell for the eternal damnation, torment and suffering of thieves.
Nice intro. Very positive review. I wish I had bought mine ten years ago instead of two if they were made like that. I had negative results with mine all the way. The belt pouch is very nice and the scissors were plenty useful though.
Welcome to the forums!
Now I want a Leatherman wave.......Thanks a bunch Sambo:p
Thanks for the great review.I like to hear of a product withstanding the test of time.
