- Jul 20, 2007
I have some questions about machining, particularly using a milling machine.
I have to make some 1/2"x1.5"x12" pieces for my kmg clone in my high school shop class. So far I have cut two strips off a large 1/2" plate with oxy-acetylene, rough ground the edges, and machined them on our milling machine.
I have been using a 3" hss slab mill bit and conventional milling. My problem is that the strips are not wide enough to sit in the vise, I have tried to raise the piece up with a metal strip, but they didn't sit flat and I had to re-do them by cutting off another strip
. Right now I am clamping half in the vise, doing one side, then flipping it around. Very painstaking.
Is there any other way of clamping it to the bed? My shop teacher said I could use a piece of wood to raise it in the vise, but most of the time says just to forget about it and get some 1.5" tubing
Is it possible to use the side of a vertical mill bit? All of the bits in my school shop dull, some are so dull it is embarrassing. I am jealous of Nathan the Machinist's thread about drilling into a file.
When these plates are done, I will have to bolt them together to form a box for the tool arm. Can I drill that deep in the milling machine or do I have to use the drill press?
Another question, the milling machine vise is really hard to turn in the last inch, I blew it out with air and gave it oil, but i would still have to give it my weight to turn it shut. How can this be fixed? I have a block beside my piece in the mean time.
Thank you!
Thank you!
