Well I finally finished my first kit knife...and now I have a few questions before I start another knife.
I used a laminated wood block to make the handle, what's the best way to finish this stuff? I wound up using a polyacrylic clear finish and it looks fine, is there anything preferred, or anything to avoid?
The biggest problem I had in finishing the kit was drilling the hole for the tang. My approach was to drill a series of holes all in a row, which sounded simple enough. In practice, the drill bit kept slipping into the previously drilled hole. This step was rather frustrating, but I eventually got through it, though it wasn't pretty. Is there any easy way to drill this hole?
I'd like to start creating my own blades now. I've only got hand tools to work with though. What's a good steel to start out with? I'm not planning on using these knives extensively, or in extreme conditions, so I just need something that's easy to work, any suggestions?
After I get a bar, I need to soften it first right? Will a simple blow torch do the job? After I've got the blade shape I want, I'll need to have it heat treated somewhere, yes? Where can I find a place to have this done?
I think that's about it for now, I'll be back with more later though
-- Mark Ciampalio
-- Mark Ciampalio
