A few Spyderco & a couple of Bokers, Chokwe, Caly3.5, Para, Police 3, Military
Feedback: +13 / =0 / -0
*Original owner. All pieces are new in box. Original edge, never used or carried. Excluding the the police3 see discription below*
I accept PayPal (fees included) but shipping (with tracking) is extra due to the range of destinations. If you have any questions feel free to ask. Not looking for trades Thank you.
Chokwe (C132G) $135
Steel CPM S30V
Overall Length 8.5 " (216 mm)
Blade Length 3.75 " (95 mm)
Closed Length 4.75 " (121 mm)
Blade Thickness .125 " (3 mm)
Edge Length 3.375 " (86 mm)
Weight 3.7 oz. (104 g)
Handle G-10 / Titanium
Caly 3.5 G10 (C144G) $120
Steel VG-10
Overall Length 7.625 " (194 mm)
Blade Length 3.5 " (89 mm)
Closed Length 4.313 " (110 mm)
Edge Length 3.125 " (79 mm)
Weight 3.1 oz. (89 g)
Handle G-10
Military(all black) (C36GBK) $140
Steel CPM S30V
Overall Length 9.5" (241 mm)
Blade Length 4" (102 mm)
Closed Length 5.5" (139 mm)
Edge Length 3.687" (94 mm)
Blade Thickness .145" (3.7 mm)
Weight 4.5 oz (128 g)
Handle G-10
SPYDERCO PARA MILITARY 2 $120
Overall Length:8.28"
Blade Length:3.44"
Blade Thickness:0.14"
Blade Material:CPM-S30V
Blade Grind:Flat
Finish:Satin
Handle Length:4.81"
Handle Thickness:0.46"
Handle Material:G-10
Weight:3.75 oz.
Lock Type:Compression Lock
SPYDERCO POLICE 3 $120
The Police 3 blade is flat-ground VG-10: a high carbon, cobalt enhanced steel that sharpens-up easily and retains its edge. Mid-positioned backlock features a David Boye Dent for added lock security.Has been carried and lightly used, only sign of use is marks on the clip
Overall Length:9.91"
Blade Length:4.35"
Blade Thickness:0.12"
Blade Material:VG-10
Blade Style:Spear Point
Blade Grind:Flat
Finish:Satin
Handle Length:5.56"
Weight:5.00 oz.
BOKER EPICENTER $120
Overall Length:8.375"
Blade Length:3.50"
Blade Thickness:0.16"
Blade Style: Drop Point
Blade Grind:Flat
Finish:Satin
Closed Length:4.875"
Handle Thickness:0.60"
Handle Material:Titanium
Frame/Liner:Titanium
Pocket Clip:Tip-Up, Tip-Down
Opener:Thumb Stud
Lock Type:Frame Lock
BOKER TITAN $40
The Boker Titan is a very slender EDC and work knife. It can be carried comfortably even in a tighter pocket, due to the slim profile. The flat ground drop point blade, and the bead blasted titanium handle combines minimum weight with maximum stability. Never used or carried
Blade Length:3.625"
Blade Grind:Flat
Finish:Satin
Handle Length:5.375"
Handle Thickness:0.32"
Weight:4.10 oz.
Pocket Clip:Tip-Up
Lock Type:Lock Back
KA-BAR LARGE TDI LAW ENFORCEMENT W/ ANKLE HOLSTER(model # 1483) never used or carried $75
Overall Length:7.50"
Blade Length:3.625"
Blade Thickness:0.19"
Blade Material:AUS-8A
Hardness:57-59 RC
Blade Grind:Hollow
Finish:Black
Handle Length:3.875"
Weight:6.40 oz.
