A-frame shelter
LOL, however, I don't expect at 20 below to find too much edbris to make a shelter, anyway.
Lets hope at that temp there is some snow to cover over a debris hut frame with twigs, boughs of some sort.
That is the best textbook engineered shelter I ever seen Impressive.
Skam
Yep snow is actually a very good insulator, sled dogs will bury themselves in snow to keep warm.
Like Halcon said, a door could easily be made but I would prefer a secondary heat source, a fire with a reflector or even a candle. A nalgene filled with hot water will go a long was as well.
Has anyone ever tried hot stones warmed by the fire and covered with earth underneath you? I beleive it was Survivorman that tried it and it worked very well for him.
Works well. Takes time to heat the stones but does work.
Skam
Skammer,
To answer your main concern, I think it would be pretty easy to fashion a triangular "plug" door with evergreen boughs that could wedge in the doorway.
A good mix of suspension (boughs) and loft (leaves) will help minimize compression of ground insulation.
-- FLIX
Skammer,
-- FLIX
Agreed. I still think its about a foot too high on the inside. A lot of cold air around him in there.
Skam
"This shelter is superior to a lean-to in that it creates more dead air space (insulation)."
Well I don't know about that- I would say it depends on the availability of fire. If you hafe a way to produce fire, a lean-to with a raised bed and a fir close in front is much better in my experience. The A frame is not a house, it is a sleeping bag. A dirty, damp, buggy sleeping bag! :) Better than nothing by far, but not as good- to me- as a shelter that can incorporate a fire.
Well, horse, there are ways of incorporating a fire here, as well.
As you can see, this shelter does a better job of managing heat loss through convection.
A fire bed used in combination with this shelter works well. Then again, burrowing into debris in combination with a fire-bed works well.
I'm not saying a lean-to doesn't work well, but it is not efficient at heat loss mitigation, again, through convection.
In a cold environment, I would use a shelter of this type long before that of a lean-to, provided I had the material at hand to make it.
Perhaps it is the different areas we live in, or even our respective level of experience, but I can tell you a lean-to doesn't hold a grain of salt to a debris shelter or even an a-frame shelter.
Also, fire management throughout the night, with the lean-to set up you describe, can be taxing and calls for a sleepless night. YMMV, however!
Alan
