- Aug 25, 2003
Fired up the forge around 7 AM, after hooking up my pyrometer. Brought it up to 1800o
and heated up a 240 layer billet I made with my Brother Kook, last Friday
Im making a sgian dubh for a piper in a Celtic band.
I started by forming the point
After I got the point established, I notched the shoulders for the tang
, using a hot cutter that I made
I drew that tang out using my home made thingy (brain Fart) there
, I made it by welding a piece of 5160 to the stick and clad the end of the steel with 309 stainless stick wire, it works real well.
I cut the knife from the rest of the billet with a 4 ½ angle cutter, to draw out the tang. I really dont like using the hot cutter for that as it deforms the blade while whacking against the cutter, thats a disadvantage of a closed back horizontal forge.
While the blade was cooling from the 1st normalization, I preheated these bars to put long side the blade, when it goes into my annealing agent (vermiculite
Heres the blade before the last normalization (3 times) and final heat beginnig the annealing process (I really dont know what critical is for this steel)
The blade is cooling as I write this. I see what it's like in the morning.
So that was pretty much my day. Hope you enjoyed.
