Ok, so what recommendation is a good sleeping pad. Now, when I qualify my price requirements, keep in mind, I buy the very best I can because I know it will last. However, being laid off for the past 7 months with a family and mortgage, I am going to have to ask for suggestions that will be able to withstand 20 or so packs before I retire it for a good one...cheap yet usable is the word here.![]()
Thermarest is king -- the new Neoair model is the most comfortable and lightest, but pricey, fragile, and not very warm. Amazing for backpacking in warmer weather, though. Their more traditional models are tougher (heavier fabric), a bit warmer, and cheaper. Something like the Prolite Plus is a good model that strikes a balance between affordability, size, weight, and insulating ability. Big Agnes also makes decent inflatables.
I like Marmot bags, and the synthetic models listed above are likely to be good choices. Synthetic is heavier and bulkier than down, but more affordable and more wet-tolerant. That's probably an overrated issue most of the time, since either will be fine in damp weather. Any truly wet sleeping bag is a bummer. It's only potentially an issue when you have a soaked bag because of an emergency (capsize, fall in a river, etc.), which is a sign of a Pretty Bad Day all around.
re the ratings, this is from the Marmot website, which explains things pretty well:
http://marmot.com/node/1771
How do I read the EN hangtag?
Basically the EN hangtag shows a temperature range:
Comfort Limit Based on a standard woman having a comfortable nights sleep
Lower Limit - Based on a standard man at the lowest temp to have a comfortable nights sleep
Extreme Rating A survival rating for a standard woman
For example, the rating on our Pinnacle 15º Sleeping Bag shows:
Comfort Limit 22.2 degrees
Lower Limit 10 degrees
Extreme Rating Minus 24.7 degrees
This can be helpful in selling on the floor. Below is an example dialogue between a female customer and a store employee.
Female Buyer - I think I need a 15 degree bag.
Store Employee What temperatures are you expecting on your trip?
FB Between 15 and 25 degrees. I tend to sleep cold however.
SE You can definitely use this Pinnacle 15 bag, but you may consider buying a Zero degree bag to sleep more comfortably at the lower temperatures.
