- Oct 16, 2010
Gentlemen:
For your consideration is this vest dagger in stabilized claro walnut/CPM-154. The claro walnut has some nice crotch flame figure - it was hand rubbed to 2500 grit and waxed to a soft sheen. The solder joint is perfectly executed with no pinholes. I recessed the double guard to ease in thumb placement over the serrations in the ricasso. The double hollow ground blade transitions to a convex ground tip to eliminate tip breakage.
The hidden tang extends all the way to the butt - the handle was filled with G/flex marine grade epoxy then snugged together with a stainless corby bolt ground flush with the butt. This dagger is deceivingly light - neutral balance is at the solder joint. No sheath yet so the buyer may specify R, L, vertical, or horizontal. I hope you like it! The first "I'll take it," PM, or email gets it. $975 delivered CONUS. Paypal preferred to tsteingass@yahoo.com. Thanks for viewing and all comments are welcome.
V/R,
TK
.156" CPM-154 stock
HT to Rc 60-61
11" OAL
5 1/2" double hollow ground blade
Convex tip
Mirror finish
Stabilized crotch flame walnut
Alternative ivory inlay
Scalloped double guard
Thumb serrations on ricasso
Soldered double guard
Horizontal or vertical sheath (specify)
V/R,
TK
.156" CPM-154 stock
HT to Rc 60-61
11" OAL
Convex tip
Mirror finish
