OK, I am not trying to spread bad information with this post. I am a bit confused right this moment due to a really weird experience. I am working with 15n20 at 3/32 thick. I had some ulus I was working on and they had some crazy bends and twists. I took a piece of stainless plate (304 maybe) and a plate of pig iron, put it in my vice and dropped the ulu in between and tighten. Just a flattening jig really and crude at that. It worked great for its purpose. I then do this same routine with some small blades I made out of the same material. I did this last night. I intended to harden and temper this morning after everything is flat.
This is where I am at a loss. I get to the shop this morning and notice that one blade still has a slight bend in it. I go to straighten this blade and it snaps. I look at the grain and it is velvet. I then hit this blade with a new Nicholson bastard file, skates the file. I go to each piece I did this routine on and they all skate the file. OK, so I think, did I just plate quench 15n20. Look up on the web and can't find much. I go back out to the shop, fire up the forge, take a scrap piece of 15n20 and do the same procedure as last night. Check the steel after putting in between the plates. Skates a file, put it in the vice put pressure on it and snap. Look at the grain and it is beautiful.
So, is it possible to plate quench this steel? Is it because it is so thin?
Thank you very much for any information on this. Also, since these do appear to be hardened, and I did not temper immediately, is it to late to temper these?
Thank you very much,
Daniel Combs
Daniel Combs
