Becker BK2 or an ESSE 5 is what you want. You can chop & pry with no worries.
http://www.bladeforums.com/forums/showthread.php/839944-BK2-test-the-final-part-(LOTS-of-pictures)
If you need your knife to do more than than whats in the link above, you may have the wrong tool for the job !!! LOL![]()
That is one HELL of a knife. I'll have to pick one of those up for sure. Also, what, in your opinion, would be a good manual sharpener? I'm looking to spend less than $50, preferably in the $10-30.
The only good hollow handle is the CRK one which was [ no longer produced] made of one piece of steel.
C'mon now... Jimmy Lyle, RJ Martin, and even Anthony Marfione have made some very high quality hollow handle knives.
The hollow handle creates a severe structural weakness at the point where the blade attaches to the handle (except knives like the Cold Steel Bushman, you could work the handle on that to have a survival kit) because the blade and handle are not one piece of steel, and are held on by a nut attached to a tiny bolt-tang. All of the force exerted onto the knife will travel straight to the bolt, which can loosen the nut over time, or easily just snap off. Pretty much the worst design ever.
I use a Rapala (may be spelled wrong) 2-stage ceramin pull-though. with enough pulls, I can get a knife with the right kind of steel a razor edge. My cheapie Colt tactical folder is now my sharpest knife (even sharper than my Buck knives.
Higher end carbine pull-throughs are supposed to be pretty good in the place of a coarse stone. I would still prefer a ceramic pull-through. I should have mentioned that the sharpener costs under $3. A stropping afterwards would leave your knife with a good finish and a sharp edge.Nothing wrong with ceramic rods, just no one confuse the pull through ceramic rod sharpeners with pull through carbide blade sharpeners - the carbide blades are really horrible things to subject a blade edge to.
Well I was talking about a low end fitting for the hollow handle survival knives. The weld would still be a structural weakness, because the steel is not uniform throughout. Think of it this way- try smacking a piece of rebar against a wall, and compare it to a piece cut in half and welded together. The weld will break before the continuous piece of metal.
Well this thread has taken a turn for the technical. I am meaning that the weld would be a weak point (well except if you kind of overdue the amount of welding material) over a solid piece (like the CS Bushman- the handle/blade point was tested to sustain I think a ton of weight, like 2000 pounds). That may just be from the sheer thickness of the steel itself though.You ever try welding? or learn about the strength of welding? because based on whatever system you use most likely that weld will be structurally stronger then the rebar or metal youve just welded, for example 6010/6013 both are standard stick welding electrodes, both are rated to a 60,000 lbs per square inch of strength. (first two digits =XX,000 lbs/in2, the next two dont matter unless your welding) now ive seen some as low as 2023, and some as high as 10024, but anyway you look at it, that sucker is gunna hold, bet my life on it
