- Apr 14, 2006
thanks guys, I was hoping for some reasurance, I gotta admit it take balls to post that, you could have all made fun.![]()
What balls? You did an excellent job! :thumbup:
Doc
File knives are a great project for almost anyone. Please start with a good quality file such as Nicholson or Simmonds. Cheapo imports are usually case-hardened junk that will only dissappoint you in the end.
Fonly, did you temper the file back a bit? If not, the edge will be brittle and likely chip under use. A good starting point to temper a typical file is two cycles of one hour in the kitchen oven at 400F. This will soften it just enough so the edge isn't brittle, but will still keep a good edge. Test it with a brass rod.
On your next project, go ahead and put one or two pins through the scales/tang. JB Weld or epoxy will probably last a lifetime, but pins will add extra strength against the scales shearing off.
You may need a carbide bit to drill the tang, since you're working with hardened steel. They seem pricy, but they work great and last a long time. Set your drill to run slow and use cutting oil or tapping fluid to keep the bit cool.
Don't be afraid to take the bevels higher up the blade for a sharper, smoother-cutting knife. On a 3/16" or even 1/8" piece like that, there's plenty of steel for strength. You could go full-flat without worry, provided you temper the file as mentioned above.
Hope this doesn't sound too nit-picky! Your bevels look pretty darn even, that shows you have patience and skill. You've done a fine job and I hope you keep at itThese are just tips I've learned. Enjoy! Just don't blame me or Nick if you get hooked on knifemaking
It was a very slow process, but I had alot of control over what I did.
One other thing, do you know what type of steel the file would be?
that is a very nice looking knife.. what are your final measurements on it?
4" blade and 4" handle, 3/16" thick from I believe to be most likely 1095, or W2.
thanks for the info.. I believe you have inspired me sir.. I've never tried a file knife before, I may just have to give it a shot.
